Multi Wii Copter LCD Config
You need:
Features
  • Logging onto SD card
Hardware
LCD Keypad Shield
Hardware Keys
  1. define HWKEYS
Define the ports to use here:
  1. define HW_RIGHT 10
  2. define HW_UP 9
  3. define HW_DOWN 11
  4. define HW_LEFT 8
  5. define HW_SELECT 6
States Graphic
Simplified state chart of the LCD Config app
