Multi Wii Copter LCD Config
You need:
Features
  • Logging onto SD card
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Using ... Todo
States Graphic
Simplified state chart of the LCD Config app
