Multi Wii Copter LCD Config
You need:
Features
  • Logging onto SD card
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Adjust the ports used here:
LiquidCrystal lcd = LiquidCrystal(8, 9, 4, 5, 6, 7); // rs, enable, d4, d5, d6, d7
States Graphic
Simplified state chart of the LCD Config app
