Multi Wii Copter LCD Config
You need:
- a LCD Display, either using parallel 4 Wires or ShiftReq control
- Some keys, some cable
Features
- Logging onto SD card
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
Shift Register LCD
Adjust the ports used here:
