Multi Wii Copter LCD Config
About
You need:
- Some keys, some cable
Features
- Logging onto SD card
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
Shift Register LCD
Adjust the ports used here:
SD card connections
LED for status
Ports defined here:
States Graphic
Gallery
Schematics as PDF,.PLT, Image
