Multi Wii Copter LCD Config
About
You need:
  • a LCD Display, either using parallel 4 Wires or ShiftReq control (based on the Hitachi HD44780 (or a compatible) chipset, which is found on most text-based LCDs.)
  • Some keys, some cable
  • latest Arduino Sketch for LCD_Config: http://www.rc-heli-fan.org/download/file.php?id=91727
Features
  • Logging onto SD card
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Adjust the ports used here:
SD card connections
pin 13   SCK   SPI clock
LED for status
Ports defined here:
#define STATUS_LEDS
#define RED_LED      A1
#define YELLOW_LED   A3
#define GREEN_LED    A5
States Graphic
Simplified state chart of the LCD Config app
Gallery
Schematics as PDF,.PLT, Image
