Multi Wii Copter LCD Config
About
Features
  • Logging onto SD card
Prerequisites
  • Some keys, some cable
Download
V1.5: http://www.rc-heli-fan.org/download/file.php?id=92207
Version History
V0.8 to V1.4 see forum
V1.5
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Adjust the ports used here:
SD card connections
pin 13   SCK   SPI clock
LED for status
Ports defined here:
#define STATUS_LEDS
#define RED_LED      A1
#define YELLOW_LED   A3
#define GREEN_LED    A5
States Graphic
Gallery
Schematics as PDF,.PLT, Image
