Multi Wii Copter LCD Config
About
Features
- Logging onto SD card
Prerequisites
- Some keys, some cable
Download
Version History
V0.8 to V1.4 see forum
V1.50
V1.60
- max/min values show up again (#define option)
- some compile fixes
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
Shift Register LCD
Adjust the ports used here:
SD card connections
LED for status
LEDs are connected through 220-500 Ohm resitors.
Ports defined here:
State chart
Gallery
Schematics as PDF,.PLT, Image
