Multi Wii Copter LCD Config
About
Features
- works for Multi Wii Software 1.5 (stable) and 1.6pre
- serial communication with the MultiWii software
- same parameters changeable as in the GUI
- presents sensor data (gyro, nunchuk, acc, barometer), receiver input channels, abd output channels (ESCs and servos)
- simple graphic output for servo channels and inclination angles
- logging to SD cards
- profile management to test different settings
Prerequisites
- Some keys, some cable
Download
Version History
V0.8 to V1.4 see forum
V1.50
V1.60
- max/min values show up again (#define option)
- some compile fixes
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
Shift Register LCD
Adjust the ports used here:
SD card connections
LED for status
LEDs are connected through 220-500 Ohm resitors.
Ports defined here:
State chart
Gallery
Schematics as PDF,.PLT, Image
