Multi Wii Copter LCD Config
About
Features
  • logging to SD cards
Prerequisites
  • Some keys, some cable
Download
Version History
V0.8 to V1.4 see [1]
V1.50
V1.60
V2.0 beta
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Adjust the ports used here:
SD card connections
pin 13   SCK   SPI clock
Status LEDs
#define STATUS_LEDS
#define RED_LED      A1
#define YELLOW_LED   A3
#define GREEN_LED    A5
State chart
Gallery
Schematics as PDF,.PLT, Image
