Multi Wii Copter LCD Config
About
Features
- works for Multi Wii Software 1.5 (stable) and 1.6pre
- serial communication with the MultiWii software
- same parameters changeable as in the GUI
- presents sensor data (gyro, nunchuk, acc, barometer), receiver input channels, abd output channels (ESCs and servos)
- simple graphic output for servo channels and inclination angles
- logging to SD cards
- profile management to test different settings
Prerequisites
- Some keys, some cable
Download
Version History
V0.8 to V1.4 see [1]
V1.50
V1.60
V2.0 beta
V2.0
* swapped motors 4 and 5 in 'Esc Out' for versions 1.5 and 1.6prebis * changed behaviour of UP and DOWN for consistency (UP decrements, DOWN increments values) * added version V1.6 * output logfiles in LogView format [OPTIONAL] (file numbers starting from 500, extension ".lvw") * added JOYSTICK option to replace input buttons by an analog joystick [experimental] * display 'invalid' values in graphics * heavy optimizations (!) due to space restrictions * removed WAIT_FOR_INIT option, changed start state to 31 instead
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
Shift Register LCD
Adjust the ports used here:
SD card connections
Status LEDs
State chart
Gallery
Schematics as PDF,.PLT, Image
