Multi Wii Copter LCD Config
About
Features
  • logging to SD cards
Prerequisites
  • Some keys, some cable
Download
Version History
V0.8 to V1.4 see [1]
V1.50
V1.60
V2.0 beta
V2.0
  • swapped motors 4 and 5 in 'Esc Out' for versions 1.5 and 1.6prebis
  • changed behaviour of UP and DOWN for consistency (UP decrements, DOWN increments values)
  • added version V1.6
  • output logfiles in LogView format [OPTIONAL] (file numbers starting from 500, extension ".lvw")
  • added JOYSTICK option to replace input buttons by an analog joystick [experimental]
  • display 'invalid' values in graphics
  • heavy optimizations (!) due to space restrictions
  • removed WAIT_FOR_INIT option, changed start state to 31 instead
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Adjust the ports used here:
SD card connections
pin 13   SCK   SPI clock
Status LEDs
#define STATUS_LEDS
#define RED_LED      A1
#define YELLOW_LED   A3
#define GREEN_LED    A5
State chart
Gallery
Schematics as PDF,.PLT, Image
