Multi Wii Copter LCD Config
About
Features
  • logging to SD cards
Prerequisites
  • Some keys, some cable
Download
Version History
V0.8 to V1.4 see [1]
V1.50
V1.60
V2.0 beta
V2.0
  • swapped motors 4 and 5 in 'Esc Out' for versions 1.5 and 1.6prebis
  • changed behaviour of UP and DOWN for consistency (UP decrements, DOWN increments values)
  • added version V1.6
  • output logfiles in LogView format [OPTIONAL] (file numbers starting from 500, extension ".lvw")
  • added JOYSTICK option to replace input buttons by an analog joystick [experimental]
  • display 'invalid' values in graphics
  • heavy optimizations (!) due to space restrictions
  • removed WAIT_FOR_INIT option, changed start state to 31 instead
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Adjust the ports used here:
Logging
pin 13   SCK   SPI clock
Logfile are written either in binary format, in that way they can be sent and visualized to the MultiWiiConf software, or (starting from Version 2.0) in LogView OpenFormat, to display them in LogView. A corresponding device file for LogView (.ini) is included in the archive beginning from Version 2.0. For more details, check out www.logview.info (and don't forget to donate :)).
Status LEDs
#define STATUS_LEDS
#define RED_LED      A1
#define YELLOW_LED   A3
#define GREEN_LED    A5
State chart
Gallery
Schematics as PDF,.PLT, Image
