Multi Wii Copter LCD Config
About
Features
- works for Multi Wii Software 1.5 (stable) and 1.6pre
- serial communication with the MultiWii software
- same parameters changeable as in the GUI
- presents sensor data (gyro, nunchuk, acc, barometer), receiver input channels, abd output channels (ESCs and servos)
- simple graphic output for servo channels and inclination angles
- logging to SD cards
- profile management to test different settings
Prerequisites
- Some keys, some cable
Download
Version History
V0.8 to V1.4 see [1]
V1.50
V1.60
V2.0 beta
V2.0
- swapped motors 4 and 5 in 'Esc Out' for versions 1.5 and 1.6prebis
- changed behaviour of UP and DOWN for consistency (UP decrements, DOWN increments values)
- added version V1.6
- output logfiles in LogView format [OPTIONAL] (file numbers starting from 500, extension ".lvw")
- added JOYSTICK option to replace input buttons by an analog joystick [experimental]
- display 'invalid' values in graphics
- heavy optimizations (!) due to space restrictions
- removed WAIT_FOR_INIT option, changed start state to 31 instead
Hardware
LCD Keypad Shield
Hardware Keys
#define HWKEYS
Define the ports to use here:
Shift Register LCD
Adjust the ports used here:
Logging
Logfiles are written either in binary format, in that way they can be sent to and visualized by the MultiWiiConf software, or (starting from Version 2.0) in LogView OpenFormat, to display them in LogView. A corresponding device file for LogView (.ini) is included in the archive beginning from Version 2.0. For more details, check out www.logview.info (and don't forget to donate :)).
Status LEDs
State chart
Gallery
Schematics as PDF,.PLT, Image
