Multi Wii Copter LCD Config
About
Features
- works for Multi Wii Software 1.5 (stable) and 1.6pre
- serial communication with the MultiWii software
- same parameters changeable as in the GUI
- presents sensor data (gyro, nunchuk, acc, barometer), receiver input channels, abd output channels (ESCs and servos)
- simple graphic output for servo channels and inclination angles
- logging to SD cards
- profile management to test different settings
Prerequisites
- Some keys, some cable
Download
Version History
V0.8 to V1.4 see [1]
V1.50
V1.60
V2.0 beta
V2.0
- Swapped motors 4 and 5 in 'Esc Out' for versions 1.5 and 1.6prebis
- Changed behaviour of UP and DOWN for consistency (UP decrements, DOWN increments values)
- Added version V1.6
- Output logfiles in LogView format [OPTIONAL] (file numbers starting from 500, extension ".lvw")
- Added JOYSTICK option to replace input buttons by an analog joystick [experimental]
- Display 'invalid' values in graphics
- Heavy optimizations (!) due to space restrictions
- Removed WAIT_FOR_INIT option, changed start state to 31 instead
V2.1
- Bugfix in deserialize() with v1.6
- Joystick handling was improved (calibration, use of pullups, can be used in parallel to buttons)
- Added 'Play LogFile' state
- Easter egg function to display internal configuration :)
- BUGFIX: RC Rate multiplied by factor 2 for MWC Versions >v1.5, minimum of 20% for RC Rate (0% makes no sense)
- Added random offsets in TEST mode
V2.2
- Cancel in Logfile Playback (press LEFT_KEY)
- Settings of "Baud Rate", serialRead() has been adapted to work with different COM speeds
- Greater flexibility in changing the Settings
- (Log) Delay Time was moved to Settings state and is used as the time interval of polling the MWC board
V2.3
- Changed internal representation of state machine and strings
- Support for v1.7pre (I-/P-Level instead of AutoLevelStrength, trigger calibration, 8 instead of 5 receiver
- channels, configuration of activation modes for Aux1/Aux2, ...)
- Software Version is now stored in Logfile
- APC220 Option (disables APC220 module via pin D2 during playback of logfiles, experimental)
V2.4
- Swapped Angle and Baro/Comp/Cycle states
- Added 'Config' parameter to LogFiles, show Config and Version in selectLogFile
- Use of blinking Cursor instead of Arrows in Enter mode
- LogView mode: corrected order of receiver channels
- Greater robustness in serialWrite() method
V2.5
- Simultaneous setting of Roll and Pitch PID values ("2 PID -> Roll/Pitch")
V2.6
- Support for v1.7prebis (replaced v1.7pre)
- (Profiles generated with older versions are automatically converted to v.17prebis profiles)
- CHECK_INPUT option to visualize the joystick input (hidden state, press RIGHT key in start state for >1 sec)
- BATTERY_LEVEL option (experimental), visualisation of battery status on LCD and via Status LEDS, 4 warn levels can be defined
- Internal optimizations
Hardware
LCD Keypad Shield
Joystick
Hardware Keys
#define HWKEYS
Define the ports to use here:
Shift Register LCD
Adjust the ports used here:
Logging
Logfiles are written either in binary format, in that way they can be sent to and visualized by the MultiWiiConf software, or (starting from Version 2.0) in LogView OpenFormat, to display them in LogView. A corresponding device file for LogView (.ini) is included in the archive beginning from Version 2.0. For more details, check out www.logview.info (and don't forget to donate :)).
Status LEDs
State chart
(the state chart is not up to date!)
Gallery
Schematics as PDF,.PLT, Image
