Multi Wii Copter LCD Config
About
Features
  • logging to SD cards
Prerequisites
  • Some keys, some cable
Download
Version History
V0.8 to V1.4 see [1]
V1.50
V1.60
V2.0 beta
V2.0
  • Added version V1.6
V2.1
  • Added 'Play LogFile' state
V2.2
V2.3
  • Changed internal representation of state machine and strings
  • Support for v1.7pre (I-/P-Level instead of AutoLevelStrength, trigger calibration, 8 instead of 5 receiver
  • channels, configuration of activation modes for Aux1/Aux2, ...)
  • Software Version is now stored in Logfile
  • APC220 Option (disables APC220 module via pin D2 during playback of logfiles, experimental)
V2.4
  • Swapped Angle and Baro/Comp/Cycle states
  • Added 'Config' parameter to LogFiles, show Config and Version in selectLogFile
  • Use of blinking Cursor instead of Arrows in Enter mode
  • LogView mode: corrected order of receiver channels
  • Greater robustness in serialWrite() method
V2.5
  • Simultaneous setting of Roll and Pitch PID values ("2 PID -> Roll/Pitch")
V2.6
  • Support for v1.7prebis (replaced v1.7pre) and also v1.7preter
  • (Profiles generated with older versions are automatically converted to v.17prebis profiles)
  • CHECK_INPUT option to visualize the joystick input (hidden state, press RIGHT key in start state for >1 sec)
  • BATTERY_LEVEL option (experimental), visualisation of battery status on LCD and via Status LEDS, 4 warn levels can be defined
  • Internal optimizations
V2.7
  • Added consistency check in serialRead, removed strange behaviour after framelength errors.
  • Improved error handling when communication fails (more detailed description than "Inv. FrameLength")
  • Show MWC version in start state
  • Show current values in "Settings" state, added blinking cursor when entering values
  • Number of Profiles can be configured (constant NUM_PROFILES)
Hardware
LCD Keypad Shield
Joystick
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Adjust the ports used here:
Logging
pin 13   SCK   SPI clock
Status LEDs
#define STATUS_LEDS
#define RED_LED      A3
#define YELLOW_LED   A4
#define GREEN_LED    A5
State chart
(the state chart is not up to date!)
Gallery
Schematics as PDF,.PLT, Image
