Multi Wii Copter LCD Config
About
Features
  • Versions prior to 4.0 work with MultiWiiCopter (MWC) Software Versions 1.5 - 1.7, Version 4.0 with MWC Version 1.8, Version 4.1 with MWC Version 1.8 and 1.9
  • Automatic configuration to MWC version (starting from v4.0)
  • Serial communication (like the MultiWiiConfig tool)
  • Presentation and editing of the complete set of parameters
  • Emulation of a serial TEXTSTAR LCD to use the built-in configuration mode in the MWC software
  • Profile management to test different settings
  • Logging to SD cards (optional), playback of Logfiles via MultiWiiConfig or via LogView
  • Support for APC220 Wireless Module (optional)
  • Highly configurable (footprint of executable ranges from 13k to 28k).
  • Optionally displays the maximum and minimum values of the received data
  • Simple graphic output for servo channels and inclination angles (and bar-charts in TEXTSTAR mode)
Hardware Requirements
  • An Arduino board Boards (Arduino Uno/Duemilanove, Pro Mini, Nano...) with ATMega168 or ATMega328 (preferred)
  • A HD4408 or compatible LCD (e.g., DFRobot LCD Keypad Shield) (other options exists, e.g., Eagle Tree Power Panel or a Serial LCD) - see schematic below
  • Four push-buttons (as provided by the LCD Keypad Shield) or a two-axis analog joystick (or both), push-buttons can be connected either on separate input ports or via cascading resistors.
  • (Optional) SD Card interface (e.g., DFRobot Interface Shield) for Logging
  • (Optional) APC220 Wireless Module (simulates a standard serial connection)
Software Requirements
  • Arduino v022
Download
V3.2: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&start=810#p1264382 (last version supporting MWC version 1.5-1.7)
V4.0: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&p=1279371#p1279371 (supporting MWC version 1.8)
V4.1 beta 1: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&start=915#p1314499 (supporting MWC version 1.8-1.9)
V4.1 beta 2: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&start=915#p1315788
Version History
V0.8 to V1.4 see [1]
V1.50
V1.60
V2.0 beta
V2.0
  • Added version V1.6
V2.1
  • Added 'Play LogFile' state
V2.2
V2.3
  • Changed internal representation of state machine and strings
  • Support for v1.7pre (I-/P-Level instead of AutoLevelStrength, trigger calibration, 8 instead of 5 receiver
  • channels, configuration of activation modes for Aux1/Aux2, ...)
  • Software Version is now stored in Logfile
  • APC220 Option (disables APC220 module via pin D2 during playback of logfiles, experimental)
V2.4
  • Swapped Angle and Baro/Comp/Cycle states
  • Added 'Config' parameter to LogFiles, show Config and Version in selectLogFile
  • Use of blinking Cursor instead of Arrows in Enter mode
  • LogView mode: corrected order of receiver channels
  • Greater robustness in serialWrite() method
V2.5
  • Simultaneous setting of Roll and Pitch PID values ("2 PID -> Roll/Pitch")
V2.6
  • Support for v1.7prebis (replaced v1.7pre) and also v1.7preter
  • (Profiles generated with older versions are automatically converted to v.17prebis profiles)
  • CHECK_INPUT option to visualize the joystick input (hidden state, press RIGHT key in start state for >1 sec)
  • BATTERY_LEVEL option (experimental), visualisation of battery status on LCD and via Status LEDS, 4 warn levels can be defined
  • Internal optimizations
V2.7
  • Added consistency check in serialRead, removed strange behaviour after framelength errors.
  • Improved error handling when communication fails (more detailed description than "Inv. FrameLength")
  • Show MWC version in start state
  • Show current values in "Settings" state, added blinking cursor when entering values
  • Number of Profiles can be configured (constant NUM_PROFILES)
2.7
  • Removed BATTERY_LEVEL problem in conjunction with APC220
  • Flashing in battery status display to indicate warn levels
  • Bugfix in setting of delay time
2.9
  • KEY_PIN can be undefined if no cascading Buttons are used
  • Changed default values for Version (highest version) and Baudrate (115200)
  • Added Option "Dump Buffer" to show the contents of the data buffer when an invalid frame is received (for debugging)
  • DEFAULT_BAUDRATE can be configured, USE_DEFAULT_BAUDRATE ignores stored Baudrate params (Baudrate can still be adjusted manually)
  • Bugfix in state "Enter R/C Rate / Expo" (no action on RIGHT)
  • Bugfix concerning Battery level (removed leading extra byte)
3.0
  • Bugfix in "Enter PID Level" state
  • deleted JS_INV_SELECT_KEY - the Joystick SELECT Button must be connected to GND.
3.1
  • Support of EagleTree PowerPanel (thx to Danal Estes) and Sparkfun Serial LCD
3.2
  • Bugfix in "restoreParams()"
  • Changed Serial LCD from SoftwareSerial lib to NewSoftSerial lib - see http://arduiniana.org/libraries/NewSoftSerial/
  • Added EMULATE_SERIAL_LCD option to use the LCD_Config as a Serial LCD (option LCD_CONF has to be enabled in MWC software). To enter the emulation state press KEY_RIGHT during the initial 'Reading' state. This feature allows you to use the LCD_Config with MWC versions not supported by LCD_Config (i.e., the developer version).
  • In "Reading..." state, the characters '<' and '>' indicate which keys are currently selectable. ('<' to cancel, '>' to enter the fabulous 'Serial LCD Emulation' mode.)
  • Extracted option section to separate Header file and moved all #includes to the beginning of the sketch, the user should ONLY edit this file and the comments in the #includes
4.0
  • Full support for MWC v1.8
  • Versions <v1.8 are no longer supported (except via the EMULATE_TEXTSTAR / LCD_CONF Option)
  • EMULATE_SERIAL_LCD replaced by the more powerful EMULATE_TEXTSTAR Option
  • Removed BATTERY_LEVEL Option (now mandatory), added support for POWERMETER
  • Added new config "Octocopter"
  • Added "Calibrate Mag(neto)"
  • Supports LCD_TELEMETRY Displays (incl. Bar charts) via EMULATE_TEXTSTAR
4.1
  • Support for MWC v1.9
  • Bugfix in Serialisation
  • Bugfix in Profile Management
  • Bugfix "Enter PowerTrigger" value
  • Presentation of MWC Version when selecting Profiles
  • Changed menu structure of the State "0 - Config". Press RIGHT to show sensor status, trigger calibration or set activation modes.
  • Presentation of GPS data (not yet fully supported by the MWC software)
Hardware
LCD Keypad Shield
Joystick
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Adjust the ports used here:
Serial LCD
Logging
pin 13   SCK   SPI clock
Status LEDs
#define STATUS_LEDS
#define RED_LED      A3
#define YELLOW_LED   A4
#define GREEN_LED    A5
Emulation of TEXTSTAR display
#define LCD_CONFIG
#define LCD_TEXTSTAR
The emulation mode is entered by pressing the RIGHT button immediately after initialisation. To stop, press the SELECT key (or RESET).
State chart
Gallery
Schematics as PDF,.PLT, Image
