Multi Wii Copter LCD Config
About
Features
  • Versions prior to 4.0 work with MultiWiiCopter (MWC) Software Versions 1.5 - 1.7, Version 4.0 with MWC Version 1.8, Version 4.1 with MWC Version 1.8 and 1.9
  • Automatic configuration to MWC version (starting from v4.0)
  • Serial communication (like the MultiWiiConfig tool)
  • Presentation and editing of the complete set of parameters
  • Emulation of a serial TEXTSTAR LCD to use the built-in configuration mode in the MWC software
  • Profile management to test different settings
  • Logging to SD cards (optional), playback of Logfiles via MultiWiiConfig or via LogView
  • Support for APC220 Wireless Module (optional)
  • Highly configurable (footprint of executable ranges from 13k to 28k).
  • Optionally displays the maximum and minimum values of the received data
  • Simple graphic output for servo channels and inclination angles (and bar-charts in TEXTSTAR mode)
Hardware Requirements
  • An Arduino board Boards (Arduino Uno/Duemilanove, Pro Mini, Nano...) with ATMega168 or ATMega328 (preferred)
  • A HD4408 or compatible LCD (e.g., DFRobot LCD Keypad Shield) (other options exists, e.g., Eagle Tree Power Panel or a Serial LCD) - see schematic below
  • Four push-buttons (as provided by the LCD Keypad Shield) or a two-axis analog joystick (or both), push-buttons can be connected either on separate input ports or via cascading resistors.
  • (Optional) SD Card interface (e.g., DFRobot Interface Shield) for Logging
  • (Optional) APC220 Wireless Module (simulates a standard serial connection)
Software Requirements
  • Arduino v022
Download
(Note: the version of the LCD_Config does not correspond to the version of the MultiWiiCopter software.)
V3.2: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&start=810#p1264382 (last version supporting MWC version 1.5-1.7)
V4.0: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&p=1279371#p1279371 (supporting MWC version 1.8)
V4.1 beta 1: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&start=915#p1314499 (supporting MWC version 1.8-1.9)
V4.1 beta 2: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&start=915#p1315788
V4.1 beta 3: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&start=945#p1317261
V4.1: http://www.rc-heli-fan.org/viewtopic.php?f=255&t=80336&start=945#p1317951
Version History
V0.8 to V1.4 see [1]
V1.50
V1.60
V2.0 beta
V2.0
  • Added version V1.6
V2.1
  • Added 'Play LogFile' state
V2.2
V2.3
  • Changed internal representation of state machine and strings
  • Support for v1.7pre (I-/P-Level instead of AutoLevelStrength, trigger calibration, 8 instead of 5 receiver
  • channels, configuration of activation modes for Aux1/Aux2, ...)
  • Software Version is now stored in Logfile
  • APC220 Option (disables APC220 module via pin D2 during playback of logfiles, experimental)
V2.4
  • Swapped Angle and Baro/Comp/Cycle states
  • Added 'Config' parameter to LogFiles, show Config and Version in selectLogFile
  • Use of blinking Cursor instead of Arrows in Enter mode
  • LogView mode: corrected order of receiver channels
  • Greater robustness in serialWrite() method
V2.5
  • Simultaneous setting of Roll and Pitch PID values ("2 PID -> Roll/Pitch")
V2.6
  • Support for v1.7prebis (replaced v1.7pre) and also v1.7preter
  • (Profiles generated with older versions are automatically converted to v.17prebis profiles)
  • CHECK_INPUT option to visualize the joystick input (hidden state, press RIGHT key in start state for >1 sec)
  • BATTERY_LEVEL option (experimental), visualisation of battery status on LCD and via Status LEDS, 4 warn levels can be defined
  • Internal optimizations
V2.7
  • Added consistency check in serialRead, removed strange behaviour after framelength errors.
  • Improved error handling when communication fails (more detailed description than "Inv. FrameLength")
  • Show MWC version in start state
  • Show current values in "Settings" state, added blinking cursor when entering values
  • Number of Profiles can be configured (constant NUM_PROFILES)
2.7
  • Removed BATTERY_LEVEL problem in conjunction with APC220
  • Flashing in battery status display to indicate warn levels
  • Bugfix in setting of delay time
2.9
  • KEY_PIN can be undefined if no cascading Buttons are used
  • Changed default values for Version (highest version) and Baudrate (115200)
  • Added Option "Dump Buffer" to show the contents of the data buffer when an invalid frame is received (for debugging)
  • DEFAULT_BAUDRATE can be configured, USE_DEFAULT_BAUDRATE ignores stored Baudrate params (Baudrate can still be adjusted manually)
  • Bugfix in state "Enter R/C Rate / Expo" (no action on RIGHT)
  • Bugfix concerning Battery level (removed leading extra byte)
3.0
  • Bugfix in "Enter PID Level" state
  • deleted JS_INV_SELECT_KEY - the Joystick SELECT Button must be connected to GND.
3.1
  • Support of EagleTree PowerPanel (thx to Danal Estes) and Sparkfun Serial LCD
3.2
  • Bugfix in "restoreParams()"
  • Changed Serial LCD from SoftwareSerial lib to NewSoftSerial lib - see http://arduiniana.org/libraries/NewSoftSerial/
  • Added EMULATE_SERIAL_LCD option to use the LCD_Config as a Serial LCD (option LCD_CONF has to be enabled in MWC software). To enter the emulation state press KEY_RIGHT during the initial 'Reading' state. This feature allows you to use the LCD_Config with MWC versions not supported by LCD_Config (i.e., the developer version).
  • In "Reading..." state, the characters '<' and '>' indicate which keys are currently selectable. ('<' to cancel, '>' to enter the fabulous 'Serial LCD Emulation' mode.)
  • Extracted option section to separate Header file and moved all #includes to the beginning of the sketch, the user should ONLY edit this file and the comments in the #includes
4.0
  • Full support for MWC v1.8
  • Versions <v1.8 are no longer supported (except via the EMULATE_TEXTSTAR / LCD_CONF Option)
  • EMULATE_SERIAL_LCD replaced by the more powerful EMULATE_TEXTSTAR Option
  • Removed BATTERY_LEVEL Option (now mandatory), added support for POWERMETER
  • Added new config "Octocopter"
  • Added "Calibrate Mag(neto)"
  • Supports LCD_TELEMETRY Displays (incl. Bar charts) via EMULATE_TEXTSTAR
4.1
  • Support for MWC v1.9
  • Bugfix in Serialisation
  • Bugfix in Profile Management
  • Bugfix "Enter PowerTrigger" value
  • Presentation of MWC Version when selecting Profiles
  • Changed menu structure of the State "0 - Config". Press RIGHT to show sensor status, trigger calibration or set activation modes.
  • Presentation of GPS data (not yet fully supported by the MWC software)
  • Presentation of 'Debug' values
  • Configuration of Key Ids
Hardware
LCD Keypad Shield
Joystick
Hardware Keys
#define HWKEYS
Define the ports to use here:
#define HW_RIGHT    10
#define HW_UP        9
#define HW_DOWN     11
#define HW_LEFT      8
#define HW_SELECT    6
Shift Register LCD
Adjust the ports used here:
Serial LCD
Logging
pin 13   SCK   SPI clock
Status LEDs
#define STATUS_LEDS
#define RED_LED      A3
#define YELLOW_LED   A4
#define GREEN_LED    A5
Emulation of TEXTSTAR display
#define LCD_CONFIG
#define LCD_TEXTSTAR
The emulation mode is entered by pressing the RIGHT button immediately after initialisation. To stop, press the SELECT key (or RESET).
Backlight
Enables setting of the Backlight intensity of a HD44780 based LCD.
CHECK_INPUT
Useful to calibrate the I/O devices. Shows the state of the input ports connected to the push-buttons or joystick axes. To enter this state, press the LEFT button for more than one second in State "0 - Config".
TEST
Offline Test-mode for Development
DUMP_BUFFER
If activated, dumps the contents of the read buffer in hexadecimal on the LCD when an invalid frame is read. Useful to track problems on the Serial interface.
State chart
Gallery
Schematics as PDF,.PLT, Image
