BEC
lineares BEC
Übersicht externer BEC's
RC-Power | X-fly Externes BEC 3A 5V/6V ESC 30 | 2s bis 6s LiPo | 5; 6 | 3 | - | 15,- |
Turnigy | uBEC-8A/15A / Test | 2 - 3s LiPo | 5; 6 | 8 | getaktet | ~15,- |
Turnigy | uBEC-5A/7,5A | 3 - 10s LiPo | 5; 6 | 5 | getaktet | ~15,- |
SportBEC | SportBEC 5/6V | 3 - 6s LiPo | 5; 6 | 3.5 | getaktet | 29,- |
